Open mixer software on Custom hardware
Hello all!
Recently I have made an MIDI controller, which allows me to control audio levels on my PC via phisical control. When I showed it to my audio engineering friends, a new idea has been born. The idea is, to add an digital audio interface to it and a usb/sd card port for playback. Goal for this new project, is to make a cheap mixer/premixer for schools, small venues and irregular event organizers, which would na a cheap and easy way to play pre-recorded audio and mix in small amount of external devices. I’m also thinking about giving all the inputs to the user as an USB audio interface so they could use it for recording podcasts etc.
After months of fight with creating UI for the MIDI machine, I don’t know whether I want to make it again from grounds up with even more needed futures. And here after a very long preamble, comes my question – would kt be possible to run the Open Mixer Software on a cheap microcontroller/SoC SBC, and modify it to add things needed for it to have needed additional futures.
Thans in advance,
Antoni
It depends :slight_smile:
As long LVGL is running on it, it should work.
Without Linux you have to deal with the Hardware, but thats maybe covered by Arduino or other Runtimes.
Theoretically, my current main unit (ESP32-S3, on the midi console) supports LVGL, but I was not been able to make it run without any graphical issues.
As for running Linux on it — I’ve seen other do it, so there is a big chance that it will work (although there might be an problem with integrating it with current code base for the MIDI platform, but maybe I will be able to integrate MIDI into linux soft).
I’ll try to build it in following days, and seeing how does it perform.
Linux on ESP32-S3 with only 512KB RAM? I don’t think that’s possible.
  • up to 16 mb of PSRAM (theriticly you can expand both it and the flash to 1 gig modules).
Here’s a esp32 forum topic with dev log from running a linux port on it:
